Sometimes advance v carve leaves a blank area that will not be carved. the outside perimeter is completed, but there is no toolpath for a random section. Any idea how to correct that problem?
Post your file. Usually when adv vcarve does not cut part of pocket that part of pocket is too small for size of endmill. If 1/8 endmill is selected and area is 1/16 then endmill will skip that part but vee bit will try to pocket that area.
Send such files in to support@carbide3d.com and we’ll do our best to assist.
I don’t use Carbide Create, but sometimes in some of the software I use, changing the stepover value will correct the toolpath.
