I have a Shapoko XXL. Recently I noticed an issue while doing a simple rectangular contour cut. One of the corners of the project was not smooth like the other 3. I then noticed there was a bad spot in one of the belts. It looked like a one- or two-inch section was melted. I purchased the maintenance kit and replaced all the belts and v wheels. While I was at it, I replaced the compact router as well with the ER11. I just ran my first project, and it looks terrible. The octagons seem like they are all distorted when the pocket portion of the Adv V-Carve ran. Then when the v-carve portion ran it did not line up with the pocket portion at all. Is this possibly a belt tension issue? Any help at all would be greatly appreciated.
Thank you,
Jerry
If the cut file doesn’t match the 3D preview then it is almost always a machine problem — check the runout on your spindle, if the stock moved, if the machine lost steps, &c.
