Advanced Vcarve Keeps Moving
Hey does anyone have a clue why my advanced vcarve keeps moving “in” instead of doing the area I have selected? You can see I have just the outer edges selected, but it keeps wanting to do the main middle part?
and here is the same log before bringing it into carbide create…I show this to show there shouldn’t be any broken lines, because if there were, then the layers would not be able to hold their colors initially
Post the file and explain the specifics of your difficulty?
So you see the Cyan color…that’s the part I’m trying to carve, but after I’ve selected those lines in CC, I then go click Advanced V Carve, select my bits and when I come back, it’s showing the Brown area filled instead of the Cyan
YOu can disregard, I figured it out.
