Is it normal for Advanced VCarve to stop carving. I think it should go all the way to the tip like the other points in the star.
Please try v8:
https://carbide3d.com/blog/create-v8/
If it doesn’t work in the new version, send the file in to support@carbide3d.com
It should work if you use Node Editing or corner rounding to slightly adjust the geometry.
Rounding the corners worked. Thank you so much!
