Can someone explain how to use the Align / Space tool? I just noticed it for the first time this evening.
Hey Ed…
I asked this question a while back and Rob gave an answer Here. It makes sense.
Basically it takes the left/right-most or highest/lowest and either positions things relative to the stock or the last object selected so that there is equal space.
Vertical using last object (the rectangle):
The rearranging is clearer if all objects are the same size (same operation, circles only)
and aligned neatly:
Thank-you @GJM and @WillAdams, somehow I missed that.
