All was running fine, prior jobs ran without a hitch.
Today however, I get everything setup for another job and when I start the job the machine touches off the bit with BitSetter ok, but as the spindle moves for the work piece, the spindle does not start. (Bitrunner is not initiated)
Check settings and click Diagnose link and at the bottom screen it says “BitRunner Enabled: False”.
I cannot fine where to change this setting?
This is set in current versions of Carbide Motion using the Setup Wizard.
That said, I believe that setting only governs the prompts one gets, so if there’s been a fault in the electronics, changing the software configuration won’t alter this.
Carbide3D Support came through with a WIN again.
Turns out I had to rerun the wizard for a new machine, but for my same machine.
The only way to turn on the BitRunner is through that route.
