Hi, I’m trying to make a template for a couple of simple PCB’s. I need 24 rows of 18 holes with exactly the same distance apart (2.54 mm or 0.1 inch). Is there a smart way of doing this?
I think the easiest way would be to delete all but the lower left hole, then use the linear array to create your pattern. Group the pattern after creating to keep them together.
