If we could create Contour cuts with negative start values, then it would be easy to deliberately create Air Cuts.
This would allow a final view of the cutting perimeter in the actual job, as a final check that things are aligned properly.
As an unusual value, perhaps a warning could be emitted that this will create an air cut, rather than disallowing the operation as it does now.
