I’ve come to the conclusion that I think the end mill may have been damaged when I got it. It was an Amazon purchase, and the closer I look at it (albeit without a magnifying glass) the more I think there is some tip damage. This thread is definitely enlightening though since I ran a few more tests with my .02" tapered ball nose end mill and got really good results at about 40 IPM at 10k.
Look at the endmill under magnification. You simply can’t get very far without a good look at what you’ve done to any endmill (even larger ones) - the cut I see here says rubbing and loading, maybe even broken tip. A little lubrication goes a long way too - 99% alcohol works great for this - just a few drops at the cut keeps things clean, keeps the chips from being recut (they immediately work harden and tear the edges off the mill), it’s cheap, and works. Get a 10x loupe (cheap!) and look, you’ll be surprised at what you see!
