When in the rectangle parameter setting, after you enter width, I normally “tab” to enter height, but when I tab to that box, it doesn’t highlight the field to enter, it just goes to the end of the numbers and you have to backspace or mouse over it. Not a big deal, but just annoying.
As a workaround, hitting Ctrl+A will select everything in the edit box once you have tabbed to it.
Even more annoying - I can see that when I tab to the box, everything is selected! and then it immediately unselects. Except when it doesn’t, and sometimes leaves everything selected.
