Another Touch probe Z axis adjustment?
It appears that the Z axis on my touch probe is off. Here is the workflow that I have been using per the tutorial/videos. Setting stock origin at corner I place the touch probe with the “lips” overhanging the edges and zero probe X,Y,Z. When zeroing the Z axis only, I place the touch probe on the stock and probe Z. In both cases when I run the gcode the tool starts cutting above the stock and of course the desired depth is never reached. However, if for example I probe X,Y,Z then re-zero the Z axis using the paper sheet method the cut is performed properly and the desired depth is achieved. The X & Y probe seems to be accurate.
Is there no way to adjust the touch probe offsets in GRBL using the MDI screen? In my material set up the origin is set to top of stock surface. It happens when I use either CC or VCare Pro to generate the gcode and the C3D touch probe. I’m not using an aftermarket probe.
Thanks for any help.
Craig
Craig,
How far off are we talking?
Please provide a step-by-step set of instructions which result in the wrong depths and a photo of the underside of your BitZero to us at support@carbide3d.com and we’ll do our best to work through this with you.
Which Z-axis do you have? Where is the bit relative to stock when you rapid to Z-zero +6mm in the rapid menu? Is it consistent each time?
My Z axis is the standard one. Still waiting on the Z plus to be available for upgrade.
The distance above the work it starts to cut s approximately 1/8" or 3.175mm.
I will up load a photo of the touch probe bottom and step by step to support tonight.
Thanks for all the help.
Craig
How “off” exactly is the cut? Maybe by exactly the depth of the pocket in the probe? Is the probe used with the light up or down (should always be up)?
It is about the same height as the recess in the bottom. I measured the “Lip” and it is about 1/8". The light is up and the “lips” hanging over the corner of the stock and pushed up to contact with the X & Y axis of the stock for X,Y, & Z probing. On top of the stock, light up for Z only probing.
I just uploaded the photo and step by step to support. No real hurry on my part as this is a hobby for me but it does defeat the automation of setting X,Y. & Z if I have to go back and set Z again using a piece of paper.
Thanks for the help!
Craig
Not overhanging the lip, right?
Yes, fully on top of the stock.
