I’m in the process of building out an enclosure for my Shapeoko. I live in a dry climate where static risk is higher. Planning on going with acrylic on all sides but have a few questions around that…
Would it be beneficial to go with acrylic with antistatic/electrostatic-dissipative properties? The cost seems to be threefold higher, which I’m fine with if there is a significant enough benefit.
Does layering acrylic (with or without space in between) affect static dissipation one way or another?
A bit unrelated, but is there a risk of static within the environment of the machine causing combustion when milling certain woods or carbon fiber?
