Hey gents / gals -
I created a 15’ radius dish in Rhino, 24" x 24" x 1" thick to be carved out of MDF. I’ve imported the model into Aspire and created a roughing and finishing pass but cannot get a perimeter cut using the imported model.
Is there a way to select the outer edge of the model and then create a tool-path to cut the outside the perimeter?
As a ‘workaround’, I’ve created a vector at the same dimensions as my imported STL ‘15DISH’ file (scaling down the 3D model to 23.8" so I can use 24" square pieces of MDF to maximize materials) and created a perimeter cut on the outside of that vector. I’m wondering if there’s another way to approach / streamline this.
I’ve attached some screenshots of the rough / finishing pass (can’t upload the aspire file here).
Also, machining time is just over 11 hours! I’m using the dealt settings for the 1/4" ball and EM… is there anything I can do to improve carve times?
Thanks in advance!
Mike
