Any possibility to see these features?
Are there any plans to include these features in future updates?
  1. Leaving tabs at last used size? I always use 5x5mm tabs but each time I create a toolpath, they go back to 12x3mm.
  2. Is it possible to delete the default tool library so that I see only the bits I have? The default library database CSV file (in windows explorer) shows only my added bits but all the others seem to be embedded in the program.
  3. Can the simulation have the same speed realistic for all toolpaths and tools? When previewing, some tooplaths, like pockets, appear instantly, while contour paths are slow. When I slow down the simulation, to preview the pockets, the contours are painfully slow but when I speed up the simulation, the pockets or drill toolpaths just appear all in a blink of an eye.
  4. Can the last bit used be as the default one for a new toolpath? Mine always resets to #102 1/8 each time I open Carbide Create while I use 1/4 all the time.
Most of your requests can be done by making a template file setting it to be read only, then double-clicking on it to launch the program. Let us know if you have any difficulties with doing this.
