Before I go to the trouble to draw one up in CAD, anyone have a drawing for a Dewalt 7491 zero clearance table saw insert? Thought I would find one pretty quickly in the googlnator, but apparently…not.
Did you check Grabcad specifically?
Yup, no joy. Unless I have truly awful keyword choice…and I don’t think they’re that bad.
Can’t remember is this was for that model or the smaller one or if there is a difference.
I never cut it, so try if you’d like.
https://a360.co/2YKcOSn
Will give it a look, thanks!
try this just eliminate the dado cutout https://www.stlfinder.com/model/dewalt-table-saw-dado-throat-plate-LStnUwFb/7661627
@mikep Let me know if you cut that throat plate I modeled. Your post reminded me that I never finished that project. I know you know your way around Fusion 360, so you can remove the blade opening. My plan was to try a piece of half inch PVC… Just never got around to it.
This one is really good too, thanks!
you are very welcome
I whipped this up, it’s really rough, but it fits. I want to change out how some of this works, it’s made directly from a couple scans. Again, really rough, I’ll clean this up soon. Probably. You need to place some leveling screws yourself, use your existing one for locations.
