Unable to post process anything!
When I hover over the post processor dropdown menu it shows carbide3d GRBL, as normal, but reads it was changed 1 June 2022…?
When I try to save gcode files it generates this error- Error: Failed to open output file ‘G:\Filename\SR37 Bass\Neck\FB Down\rrr.nc’ (system error 19).
Code page changed to ‘1252 (ANSI - Latin I)’
Start time: Monday, June 6, 2022 6:28:04 PM
Code page changed to ‘20127 (US-ASCII)’
May '22 update 2.0.13162
Win 10
Every toolpath from every rendering generates the same error.
Apparently F3Z files are not supported here, am I missing something?
It will not generate code, that’s the problem. Failure to post file. First time in 5 years I’ve encountered this problem.
The only code generated is in the original post.
Yep
Fixed, it was an issue with the SD card. Usually it will tell me UNABLE TO SAVE TO…
This time it didn’t. Kind of a forest for the trees moment.
Edit- prior to last night I could get past the NC editor and Win File Explorer would tell me I couldn’t save to… Now NC editor picks it up so I “assumed” it was a Fusion issue. I’d guess something with NC editor changed during the last update.
