As I am looking through a Pocket Guide for GRBL Settings, I noticed that the default setting for $12, (Arc Tolerance), is 0.002 mm. But I find that in my Shapeoko, C3D has it set at 0.010.
What is the reason for such a course setting? Steps per mm? Memory limitations? CPU workload?
What is the tolerance capability of your stepper motor? When you post code, to what decimal place? At 0.010mm or 0.0004", I think your fine but I’m not sure of your set up.
On a Shapeoko (EDIT: some of the Shapeokos…my beloved belt-driven SO3 for sure) the step is 0.025mm anyway.
I seem to remember a post describing the arc tolerance matter at length, but I can’t seem to find it right now…
