Also, my bit setter is plugged in the side. The front I believe is for the bit zero which is an optional accessory.
Yes, that’s the back corner where all the wires come out of the pre-wired drag chain
That is the shorter connections actually the long wires all had a connector to go to the ones that go across the back I mean
Dang, I’m totally stuck……
The missing connector was the front plate extension wire I found out. I’m still afraid to turn my machine on because bitsetter won’t plug into the side port only the end port
You can test bitsetter by pressing on it. It should have a red light and then light up green if it’s working properly
I just checked my bitsetter and I can actually plug it in either. Make sure the clip is facing the machine and it clips in. At least on mine. Hopefully it helps.
Seems this adapter was on one end of the bitsetter wire. Support help me fix it. Thanks guys.!
