I for the life of me can not figure out how to close these rectangles. I have cut, added, trimmed, boolean’d. I’m at a loss. Big picture I have a 13x25 india ink stained piece of pine that I’m pocketing out the stripes and then vcarving the stars and design. Any help would be awesome. Thanks in advance
I did one of them if this is what your looking for. Copy a rectangle to the top of the design. Then use Create Curve and trace around the part of the logo needed for the curve. Then move curve up and Group rectangle and curve together. Then Delete original rectangle and move created one back in place. Maybe someone else has a better idea.
I ungrouped your boxes and then selected each box and pressed the JOIN Vector button
…and that joined that rectangle. That got rid of the purple indications of openness…See if that’s what you need.
EDIT: When I uploaded the first time, I had missed those little rectangles on the right of the emblem…here is a better version. You still have one rectangle overlapping your emblem that needs to be repaired…but I think it’s on the right track.
Because Carbide Create doesn’t have support for composite paths, the most expedient thing to do is to join this geometry together so that it is one path:
