Assembly Manual - Routing the Spindle wires?
Anyone know where the section is that I can find instructions for routing the Spindle cables through the drag chains?
My manual shows a basic router, but the Spindle has a controller box cable, a spindle adapter cable, and another set of wires with no label. Do they all go in the drag chain?
Can anyone cite the page with the instructions for this? See below:
This should be covered at:
https://my.carbide3d.com/
click on “How to VFD Spindle”
https://carbide3d.com/hub/docs/65mm-vfd-spindle/
and also see:
Saki, I wont have access to my 5 Pro until Friday. I will provide some more photos to help you along if you have not already figured this out from the reference material Will provided above.
The “green part” is just the 1/8” bit adapter for the ER-11 collet. The 1/4” adapter should be the one mounted on the spindle as shipped. At least mine was.
For the “green part”, as noted, that is a container for an ER-11 collet (should be the 1/8").
For more on this see:
https://carbide3d.com/hub/docs/er-collet-basics/
@Redlander, I don’t know if you are paid by Carbide, but you have certainly taken the most effort and provided the best guidance hands down!
