I’m assembling the Pro XXL and am confused about the the drag chain assembly. The Head Bracket I received is different than the manual (see pic). This larger bracket will mount up but it doesn’t fit in the top right corner of the X/Z assembly if I place the flange down like the instructions says. Anyone have this bracket???
That head bracket replaces the two at the back of the Z-axis.
There should be a mirrored one of the other so as to make a pair.
Write in to support if you haven’t already for further details.
