I have projects where I try a piece, and add other pieces that need the same settings etc. Can these new pieces get the settings from the “parent” piece inherited, like cutting depth, bit speed and feed settings etc.?
Assign the toolpath to a layer, then put the geometry on that layer?
did not use layers yet, I know you always recommended them, will give it a try…
You can duplicate toolpaths using the currently selected geometry (the new geometry) if working in a single file.
If you’re doing this in separate files, save the 1st, then Save As… the 2nd, keeping the geometry & toolpaths. Replace the geometry, then reassign the vectors to the toolpaths.
You can also use a .c2d file as a template with toolpaths only, and import the file into your current file, and select the geometry for the toolpath.
