Hi! I use the undo/ctrl-z feature in Create a lot, but I also increment my save files frequently when I make significant design changes. Maybe it could be an option under the settings that every save or ctrl-s action could increment by a number of zeros? I’m a newbie so two digits is plenty for me, but maybe some people would have over 99 iterations.
Yes? I start something as 01 and then change the design around 06, but I want to keep the option to go back to previous revision 05 if the design change doesn’t work out. But autosave is different - that usually saves to the same file after each revision or a set timeframe. I think having incremented files is more useful - even if it only happens on a manual save action.
Hmm, I hadn’t thought of that. I don’t use one currently but I’ll look into it. If it checks often enough to capture every iteration, that could work. Thanks!
