I have a simple outline in Autocad that I’m trying to get into CC. I only get a few arc’s and lines. I’ve exported dxf in multiple older versions. I’m losing almost all my geometry. What’s the secret? CC is so limited on laying out array’s etc. I can layout my design in minutes in Acad, CC just isn’t picking up the dxf. I’m pulling my hair out.
When I export a dxf out of Autocad for SheetCam, V-Carve Pro, or other cam software, I’ll’ default to a version 12 dxf. However, I don’t use Carbide Create.
Have you tried to open the dxf in another application to see what it looks like. In its native application it may look good but a free 3rd party application may have the same trouble as CC.
And this is the screen capture after it gets imported to CC build 530
I found I could save the file out of ACAD in an svg form. I switched to that and it worked my better but, I wondering what’s up with the dxf mechanism.
Thanks everyone for your input. This is a great resource.
I added the segments in the middle as an attempt to import. The circles never came in. I figured I could always add the circles manually at the segment endpoints. That was my reasoning/test.
Select all all entities. command PEDIT, will say The entity selected is not a polyline. Turn it into one? [Yes/No] say yes (Y)
then says Edit polylines: [Close/Open/Join/Width/Fit/Spline/Decurve/Linetype-mode/Reverse/Undo/eXit] : say Join (J) then exit (X)
save
