I have an image that I imported into my project. I was able to create a tool path for the outside circle and the two letters on the inside. I can’t get it to create a tool path on the Holy Mackerel. Can anyone tell me what i am doing wrong?
which tool at 0.125" diameter is quite a bit larger than much of the graphic and won’t fit (geometry should be endmill diameter plus 10% wider than the endmill at its narrowest point):
