Beginner VCarve Question
Hi All,
Loving my machine. Making different things and experimenting with different techniques. I want to make this for my Dead Head husband and his friends. Just a carving on a stained piece of (something…not sure yet). Finished carving will be about 10" x 24". I did a sample on pine to just try it out. Was pretty happy with it…needs some sanding, but overall, I was pleased, but not sure if it should be deeper overall.
Here’s the question. I used a 60 degree vbit and for the max depth, I tried the .20 and then “stock bottom”. There seemed to be little difference. Why is that? Also, do you think a 30 degree vbit would yield better results?
Thanks so much!
A V tool will only cut as deeply as necessary to cut a given width.
A normal V carve will cut along the center and may be distorted in appearance if the depth isn’t sufficient (but this may be used (abused?) for special effects).
An Advanced V carve will cut along the perimeter at the specified depth (where possible, it will lift up for narrow/more delicate sections) and has an option for pocket clearing.
A more acute tool will reduce the width variation caused by uneven stock, and usually is bit more forgiving (but if using normal V carving will want thicker stock / a deeper cut).
The biggest improvement you could make would be to use hardwood, rather than softer pine/fir.
Consider a 60° Downcut Vee bit (https://www.cadencemfgdesign.com/product-page/60-groovee-jenny)
Make sure your stock is as perfectly flat as you can get it. If you can leave the job on the machine, surface it flat & sand it. Stain it & let dry really well. Seal & finish the top before cutting. This will bind the grain fibers together & result in a better cut.
Did you make this yourself? I did a search & didn’t see anything like it. Really nice.
Any chance I could steal if from you?? I’d like to try it out.
Hey Will,
Thanks for the info! We did plan to use a hard wood. Maybe cherry. Going to go to our wood place and see what they have. Wanted to try it out on scrap first, though. :slight_smile:
Thanks again, so excited to do this for Tom and his friends. They’re gonna love it!
A relevant svg which may not be easy to cut.
svg file
So cool! Love this design!
