i have shapeoko 3 with zaxis updrade can i order new belts my x axis belt broke. i bought the replacement kit a year ago so i have the newer belts
We have a Maintenance Kit which has belts:
The belts are Gates GT2 profile 2mm pitch 9mm wide for an SO3 — you can order them from specialty shops such as BB Man., SDP/SI, or Texas Belting — specialty 3D printer shops such as Filastruder may have them as well.
i just need the belts
Then order from BB Man., SDP/SI, or Texas Belting or Filastruder.
can you provide the specs for the belt it is the 9mm Material Type, etc
Fiberglass reinforced (which is I believe the only material available from those vendors).
Some folks have tried kevlar from other companies.
i need to know the number of teeth when i try bbman
Number of teeth only applies to closed loop belts — you want to order open ended.
