Bevel subtract tutorial
as requested on support…
In order to subtract something, you must have a block to subtract from:
It is then possible to select the geometry which one wants subtracted:
and choose Merge type: Subtract
Apply
To then assign toolpaths one has two options:
  • select the geometry which defines only the region one wishes to work with:
and assign 3D toolpaths to that:
Or offset around the entire 3D model:
Apply
and use 3D toolpath to cut the entire design out:
