Bigger Drag chains for 80mm spindle
I am wanting to upgrade my drag chain size for my water cooled 80mm spindle from Carbide 3D. Any recommendations for those that have done it? I am also considering the Masso conversion kit and thought I might as well change out the drag chains while I am at it. Any specs of length of the current chains would be awesome too. I have the 5 Pro 4x4.
Here’s an older thread regarding larger drag chains.
You shouldn’t need to on a 5. I run my coolant lines and an so line through the factory chains along with then spindle cable.
I’ve got the C3D 80mm spindle and air blast on my S5Pro 4x4 in the original drag chains. Everything fits with all the spindle stuff going down the left side, and the air blast down the right. The spindle side just barely, and I do wish the coolant tubes were softer material. But functionally, works awesome.
Yeah, I got them all in, just want more space in there is all.
