Hey everybody, I’m making some serving trays with three pockets cut out, when the machine finishes one pocket tool path it drags through a thin layer on its way to start the next pocket, any clue as to why this is happening? I have them set up as individual tool paths. Running the Pro XXL.
Double check your retract height. If the pockets are the correct depth you are not likely losing steps. If the pockets are not the correct depth maybe you are losing steps. So most likely your retract height is too low. Let us know if that is the case.
