Bit length too short
A similar question came up and I answered here.
TL;DR long, small-diameter endmills exist but there may be other ways to achieve the results you’re after without them.
Another option for your particular case, assuming your endmill has a shoulder, might be to taper your geometry so you can cut past the endmill’s cutting depth without rubbing.
