Bit progression, Yes or No? Worth it?
There has been some talk lately about bit progression and whether it is worth it or not. Should I skip bits or not?
I always strive, but don’t always succeed, to make things on the CNC that require little to no sanding after the fact. To that end, I always follow the same bit progression and step over (10%) . Does it take longer, yes. Is it worth it, absolutely!
I start with 1/4" end mill for roughing with a .0250 stepover. Next is the 1/8" ball nose with a .0125 step over and lastly a 1/16" ball nose with a step over of .00625. These settings have proven to be very effective for me.
I’ve attached the latest piece and if you zoom in you will see just how smooth and clear that finish is. No sanding!
Just thought I would share.
I do the same progression. Depending on the job the added time cutting is equal to or less than finish sanding/cleanup
I add 3/4 and 1/2 to the list.
I hate sanding.
In roughing, surface finish is determined by depth of cut. It’s cutting many pocket paths at different Z levels. Stepover should be as much as the bit can handle.
For this job, there are no fine details the finish bit needs to get into. I try to use the largest ball mill the detail requires. What is the largest tool that will fit into these corners?
Dia      Step      Scallop
1/8      .0125     .0003
1/16     .00625    .0002
1/4      .017      .0003
1/4      .014      .0002
3/8      .021      .0003
3/8      .017      .0002
1/2      .025      .0003
1/2      .020      .0002
So you can achieve the same scallop height / smooth finish in much less time.
If you have particularly stringy / open grain wood (Ash, Oak, etc…), you can do a semi finish, e.g. 1/2 ball 0.100 stepover 0.010-0.020 stock to leave, then seal the wood before the finish cut.
This is great information. Thanks!
