Hey Everyone. Just had my Bit Runner just randomly shut off on me. The router and dust collector runs without it connected to the Bit Runner and the lights on the Bit Runner is on. Has anyone had this issue before? Not sure where the problem would be or if I need to replace it. Any information will be much appreciated. Thanks ![]()
Do you have a V1 or V2?
If V2, check the fuse.
If thatβs not it, or you have a V1, contact us at support@carbide3d.com and weβll do our best to sort this out w/ you.
The only time I have had problems with my V1 was after removing the controller cover and the connector had to be removed and put back on. The problem was the BitRunner would not come on until I wiggled the connector on the board around.
