Getting a bit frustrated…I had to reset my GRBL due to accuracy issues. Now my bit setter is off. I know I’m forgetting something easy but can’t figure it out.
Thanks in advance
Thanks in advance
The BitSetter location is done in terms of movement — if how the machine moves a given distance changes it needs to be adjusted.
The usual recommendation is to disable it, perform the calibration, then re-run the Setup Wizard:
Thanks but maybe I’m not communicating correctly. After I make adjustments to GRBL my bitsetter location is off. Then I go through setup wizard to update bitsetter and my GRBL changes and goes to 40 for X and Y rather than the changes I made for the accuracy issues.
Skip sending the (optional) Grbl download — only configure for BitSetter position.
Sorry still confused. What do I skip when setting up a new machine in set up wizard?
Downloading the Grbl settings is optional:
At that screen, do not click “Download”, instead, click “Next”.
On, thank you …I’ll give that a try
