Hi all !
Upgraded my control board last year. If I add a bit setter is the hook up straight forward or additional circuit board required ?
Thanks !
Brian
( I have Neil’s tool change post for VcarvePro installed )
If you have Proximity homing switches, and either a 4/Pro, or a 3 w/ PCB Expansion Adapter the old splitter board is no longer necessary.
For a 3 w/ the PCB Expansion Adapter, plug one accessory into the “Reserved” header on the controller, plug the other into the P(robe) connector on the PCB Expansion Adapter.
