Yesterday started a 4 hour carve finished the roughing went to change bit for finish pass and no bitsetter light no light on front of machine. I’m sure it can and will be fixed the real concern is can I return to do my finish without trashing my current project? by the way it is a 2 sided carve
You will need to output separate files for each remaining tool and manually set the Z-axis zero after changing to each new tool.
You will need to be able to use the same area you zeroed your z st for the first op available for you to zero your second tool off of.
