I have a shapeoko xl and have started to use vcarve. I am also using g-sender. Ive read and tried to understand the elements of using the bit setter. Yes i can do this manually, but would like to use the bit setter. Ive read about a modified post processor, read about a macro added, but remain totally confused as to making thus happen and setting this up. I set the machine in vcarve to shapeoko v4. In g sender ive set the machine to shapeko xl. - i guess at this point does vcarve set. “M0” with a tool change? ???
See:
If that doesn’t cover everything, check in w/ Vectric tech support.
