Is there a limit on the bit size that you can use with bit zero? I would think that very small bits would break during the checking sequence.
I use 1/16 inch bits and vee bits. Even 1 inch fly cutter works. Now BitSetter does not work with 1 inch fly cutter because it has a vvoidin the center between cutter wings.
Your bit must be within 10mm of BitZero to avoid timeout. For x y and z you must be aligned over circle for v1. You have to read instructions for v2.
