First time using bit zero. After I do the probe do I zero all or is it already done by bit zero probe?
If you did a x y and z probe the zero for each is set. If you did a z only then only z is set and x and y are still set where they were last set.
In cm jog screen is rapid positions. There are two buttons.
- Go to x and y zero position. Machine moves to current x and y zero position.
- Go to z zero + 6mm. Make a 6 mm spacer to verify 0+6mm position.
Thanks for your help
