Bit Zero v2 location Top Left vs Lower Left
Just got the bitzero v2 and was reading through the directions on set up. The directions say that you need to set the bit setter in the lower left corner. I typically set my (x,y,z)= 0,0,0 in the top left corner.
Is there a way to use the bit setter in the top left corner? Or do I need to change my set up?
At the top left corner you will need to probe three times, once each for X and Y w/ the unit at the corner, then reposition it fully on the stock and probe for Z.
Thanks i will try that.
After trying, I found that you only need to probe 2x. Once for X/Y and then for Z. Thanks for the response.
