Hi all, just getting setup with my new to me Shapeoko 3 XXL. It came with bit setter, bitzero and bitrunner, and I was able to get the first two sorted no problem. But in watching the Carbide 3D youtube video on setting up the bitrunner it says there should be a spot to indicate “automated spindle control” in the settings, and I can’t find anything like that. I have Carbide Motion build 618 if that helps.
Ok, went through the setup wizard again, indicated that there was a bitrunner connected, but it’s still not turning on for a cut. Switch is set to “auto,” router is plugged into bitrunner and switched on. Thoughts?
