Is there any way to have Bitrunner Deluxe turn on for all spindle speeds above 0?
I want to use it to turn on my spindle coolant pump.
I dont need the coolant pump on all the time, just when the spindle is running. My entire setup (S04pro, vfd, spindle, coolant pum &, fan, computer, etc) is all on one power strip. When the power strip is on, it all turns on. I think it will be excessive wear and tear on the coolant pump and fan.
Any thoughts?
I don’t think that solution will work. The spindle is turned on and off by the VFD, and is directly wired to it.
