can someone point me in the right direction for setting up vcarve pro processors to make use of my new bitrunnerv2? also have the bitsetter id like to use as well.
thanks in advance
There is nothing to do at CAM level to support the BitRunner, it will pick up the M3/M5 commands that already exist in the generated G-code, to start/stop the router.
To support the BitSetter workflow, you can use @neilferreri’s post-processor for VCarve, and when you save multiple toolpaths using multiple tools in the same output file in VCarve, it will insert the appropriate tool change commands for you.
Export multiple tools and use a suitable post processor as @Julien noted.
