BitSetter - Disabling
I made a pen plotter attachment for my Shapeoko XL.
Before testing it out I need to disable the BitSetter. I believe that is a matter of unchecking the BitSetter in the Settings dialog options. I am using Carbide Motion 513
Will the settings for the BitSetter home position be retained when I re-enable it ?
Thanks, Bill
Yes, current versions of Carbide Motion retain the BitSetter coordinates, facilitating turning it off, then on again.
Thanks Will.
Now to see if I can draw with a Shapeoko :slight_smile:
Kind of a poor man’s laser.
Bill
Wasn’t that the very first thing you did after assembling your machine (the Hello World with the Sharpie)? :slight_smile:
Looking forward to seeing the drawings you get! (I guess an XL will make for spectacular large and intricate ones)
Julien:
Credit to this gentleman’s youtube presentation on making the fixtures.
I made the third version.
Plotter Fixture for CNC
Bill
Hadn’t seen that video. It’s fantastic.
Now the question @72begin Which approach did you build and what enhancements to the design did you make?
Brandon:
I built the version that utilizes three patio door rollers.
Using the Shapeoko CNC it was easy to get the steel rods parallel. Just duplicated a pair of mounting blocks with holes for the rods.
Yes, I couldn’t leave well enough alone. I wanted to remove most of the slop in the bearings. Not super tight tolerance but better than the original. To do this I added wooden rub blocks to keep the pen mounting block from shifting in the x & y axis.
First test using a fine point Sharpie was a simple compass rose.
Bill
I am thinking of multiple color gel pens and a spring-loaded (or gravity-loaded) pen mount. :thinking:
I just reread your post. I found that I had to “clear all offsets" under the zero menu to get the next zero correct after disabling BitSetter.
Tex:
As part of the process of manually setting the X, Y & Z coordinates for use with the pen / plotter fixture I am “clearing all offsets”
I think we are saying the same thing. I am open to correction.
Bill
Tex:
Another option for a pen / plotter. This one is limited in that it only uses Mini Sharpies.
Idea from this YouTube video.
Simple Pen Holder
I used parts from my local hardware store as seen in the photo.
