Does anybody know what the connector type for the HDM bitsetter is called? I have my electronics box in a place that is pretty far from the Bitsetter, and the included cable does not even come close to reaching the electronics box. I need something approximately as long as all the other cables that go from the HDM to it’s electronics box.
I believe these are the correct plug and recepticals for each end. You’ll also need a set of crimp terminals for each. Alternatively you could replace the entire cable, but it’s a different connector on the electronics box end. The easiest way to do it is cut the cable and splice on an extension.
https://www.molex.com/webdocs/datasheets/pdf/en-us/0436400301_CRIMP_HOUSINGS.pdf
https://www.molex.com/webdocs/datasheets/pdf/en-us/0436450300_CRIMP_HOUSINGS.pdf
I agree. Just cut the cable and splice in the amount you need. Any two conductor stranded 22 gage wire should work. Like speaker wire.
