Hi! So I’m getting the hang of things with cheap bits and decided to experiment with feed speeds. I snapped a 1/16" bit and hit pause immediately. But I couldn’t find out how to switch a bit and have the bitsetter do a Z check.
I could obviously switch the bit out, but is there an option somewhere to make the bitsetter do a check? I’d hate to have to re zero the z axis mid project manually. Maybe even a “step back gcode by x seconds” would be cool too on the pause screen so if you break a bit and dont hit pause fast enough, you can switch bits, have the bitsetter do it’s thing, then step back 10 seconds so the bit hits the missed part!
