Iv just updated to the latest version of Carbide motion and my Shapeoko 5 pro no longer knows where the bit setter is. When bit setter is enabled and the machine is initialized it jogs to the back right corner and attempts to measure the tool there.
Also being able to input the bit setter location manually was vital when using tools with a larger diameter than the bit setter, where the tips of the cutter were lower on the peripheral than the center (face mills) will this feature be returning ?
