Worked a while, but now again the router drives to the place of the bitsetter properly, but it only lowers 1 inch or so, stops 3-4 inches above the bitsetter, and message posp up “initialization failed”.
Any ideas?
And last time that happened I was told to re-plug the plug, what I did, but nothing changed.
The bitzero V2 error also happened again, repeatedly: when I try to zero all the process goes well through the x-axis, but when the bit touches the southern bore wall light turns red, the process stops, and failure pops up, I have to re-initialize the process again.
Far away from thinking of going productive.
