the light on my bit setter is red and when i push the button down it turns green. The button is not jammed and feels free to move up and down. i done a search for similar problems no luck. anybody seen this before?
It sounds like the other limit switch issues where the limit always indicates down in CM while looking good at the switch, the bitsetter is just another limit switch used for a diff purpose. For reference search the forums for grbl 8, hm001 and hm008 for starters,
Iâve had this issue 3 times, all were or are in the process of being corrected by new hardware. A front plate and new controller(s). Also had some assorted wiring issues with them as well so take a look at your connections.
Get in touch with support, itâs likely going to be your path of resolution.
Thank yall for the replys. I have came across another issue also.
âwill not pull off homing switchesâ
I did contact support last night. Hopefully we can find a fix tonight and get this thing making some dust.
I will double check my wiring also this evening when i get home from work.
Asking for a friend â isnt it kinda hard to mess up the wiringâ each connector has male and female end. Most are different pin counts and can only go to 1 spot.
Please tell me if i and missing something.
