My Bitsetter (rectangular) has been having issues. The bit lands to the right side of the button and when I use a fine tipped bit, it misses it completely. Any suggestions?
Check and see if your homing switches have shifted.
Ensure that when the machine is operating it isn’t running into anything which causes lost steps.
Re-run the Setup Wizard to verify and adjust the positioning if need be.
Thank you! I will try that.
